bought a ef civic si with a blown b16 was a obd 0 b16a with aobd1 conversion i had a obd 1 b16 in my garage threw it in went to start and no fuel… i used the obd 1 injectors switch the clips cuase obd 0 clips woulnt clip in. i ground the relay green/black wire and fuel pump turns on but engine still wont start it starts wit starting fluid tho… i sniped the wires for resister box and solder together… idk were else to look. basically i believe i missing ground for fuel pump relay and something to fire injectors just dont know were im lookin now
my head hurts from reading that. idk if it was the beer or your writing.
but check your grounds (thermostat one especially)
sorry i got the pump to work ground was off thermostat now im workin on gettin injectors to fire i have power to them but no ground on each injector
wow.
fixed ecu was fucked causing injectors not to fire
