me and my buddy did all his pads on his 04 grand prix. we found out the hard way that the caliper will just pop out if it doesnt have anything to stop it and will fall out on the ground. well after that happening, we get the car all done and there is like no pedal pressure. its gotta be air cuz it feels like it gonna stop fine then it fades out and goes tot he floor. so how do I go about bleeding the brakes?? can I just bleed the line going to the wheel that we had problems with??? can I just loosen the bleed valve and pump the brake til it I get a steady stream of fluid and then tighten??
yeah i have a little hose that attaches to the bleeder, just pop the hose on the bleeder and let it sit in a cup of brake fluid. then just pump away for a while making sure to top off. i usually run a whole bunch through just to be sure.
