OK, I’ve got literally probably about 8hrs into trying to bleed this fucking thing and I’m about to set it on fire. Need ideas/help/advice
backstory: front brake was feeling rather spongy towards the end of the season last year, I dealt with it and figured I’d repair it for this season. I purchased a replacement brakeline to swap out because mine looked to be expanding under brake pressure rather than trasnferring the pressure to the caliper as designed.
I swapped out the line, and began trying to bleed the system. the lever is floppier than a flacid unusued penis. pumping 10-20x and holding, open bleader, nothing comes out. repeat for about an hour, no change in symptoms.
OK, lets buy a vacuum bleeder and give that a whirl. Nope, an hour trying that did nothing. go back to previous method for about a half hour. Nope, still dead lever.
OK, let’s try a preliminary gravity bleed overnight. Remove reservoir cap, remove bleeder, top of master cyl and leave the system open overnight to let it trickle down. Check in the morning, barely a friggen drop came out. FML
OK, maybe my master or caliper needs rebuild. I’ll call the dealer and see if I can order rebuild kits. Guy on the phone asked why I thought I needed to rebuild everything. I tell him my story sans swearwords. He says they have to be pressure bled, and I should try that before I go rebuilding everything. So I really like the shop/guy/owner (Lee) of Empire Cycle in OP on Southwestern near St. John Vianney church, I ring him up and tell him whats up…dude is so awesome he tells me he’s booked up but try these couple things first…
make sure the reservoir on the master is as level as possible, make sure the line coming out of it is pitched downward at least a little. If these arent the case, its very easy for an air bubble to get trapped right where the line mounts to the master and no matter what you do it will never bleed. He also recommended removing the caliper and letting it hang so that the bleeder is the lowest point. I just got in from spending about an hour and a half fucking with this POS again. I took all of Lee’s advice and made zero progress.
so, what else can I do/try? WTF is a “pressure bleeder” and where can I get one/borrow one?
