Inspired by Zilvia. (maybe make this a sticky)
General (S13 and S14)
Good pics but not enough details
S13 4 lug thread, Lots of BS posts
Now everyone can have flush wheels.
:partyman:
:partyman:
Wow some of those are quite flush…Not.
Maybe i will add a pic once i become Mexi-Flush like you in 2 weeks Rob.
Even if they are not flush it give you an idea of fitment.
unless you have 9;s and tens there will be no maxi flush for you! (without spacers anyways)
F@ck yer couch n*gga! My contribution…
F: 225-45-17 ON 17X9 17MM OFFSET
R: 225-45-18(WRONG SIZE) ON 18X9.5 20MM OFFSET
In the rear i have a 5mm spacer so that makes it 15mm offset. I also flared my rear fenders to make more room for the right size of tires i wanted. Which is 245-40-18 or 245-35-18 with the 5mm spacer out.
I am just guessing my alignment specs here cause i had it aligned but then i lowered some more.
F: 0 toe, max’ed on my camber plate with rolled fender, factory caster.
R: 0 toe, 1-1.5* of camber, stock caster.
Andrew’s old ride.
17x8.5+25 215/45/17
17x9.5+28 235/40/17
