OK well i got the s12 back and this weekend is gunna be busy im taking the s13’s heart out and putting it in the s12 i need help with the wiring can anyone lend a hand ?
take the s13 harness out COMPLETELY, and put in s12. problem, solved.
explain what harness ? like the front where all the fuse boxes are? can anyone show me in a diagram or something
All the wiring in the car.
that sort of helps. it would make my life alot easier if some one has a picture of a complete uncut full harness and tells me which plugs/wires to change to make this work.
ok w/e dont take it all out.
why are you getting mad ? im still pulling the harness i just dont understand how to hook it up in the s12 to work. this is the ? im asking how do i make it work
Remove every wire from car. Take tapeand mark all grounds and what goes to what.
Remove s12 harness(and save this, you may need it) and then re install s13 harness to s12 and try and connect everything.
ok thanks. ill try this the harness runs on the other side apposed to s13 do you think this will make a difference?
http://ka-t.org/fsm.php download the s13 service manual and there are charts with every harness in the car, and what each plug does, etc.
Go on club s-12. There are wiring walk-throughs for this swap.
