ok guys need help cant drive my baby. i have a 94 integra i cant figure out why my check engine light is on. i jump it and the light stays on no flashes it wont rev over 4 grand need help the car does start and run help me out guys :ham:![]()
Is there a self test mode for these ECUs?
ya there is a jumper near the ecu you can get codes from via CEL flashes, google it!
---------- Post added at 01:40 PM ---------- Previous post was at 01:38 PM ----------
http://www.team-integra.net/sections/articles/showArticle.asp?ArticleID=34
ya the light dont blink just stays on
ecu is bad, possibly filled with corrosion on the inside. I would pull it and check it out.
no corrosion its clean no fried transitors or anything
I would say the problem inside your distributor mostly likely a failing ICM or maybe a bad MAP sensor.
