Idle Air Control Valve 1g DSM
Looking for an Idle Air Control Valve for my turbo 1g.
Anyone?
Also, I could use an ECU if anyone has one kicking around.
whats your talon doing that you need a new idle air controller? is it surging/ stalling? mine does that and i think i need a new iac, but i was just wondering if you were having the same problems.
It’s surging and stalling and did so to the point that it burnt out the ECU.
Your ECU probably leaked capacitor juices all over the board. SLowly making your idle problem worse and worse untill the ecu finally just shit the bed. I have an ECU but no idea if its good or not, caps all look good but that means nothing.
Yeah, the caps and mine look fine too, but its not the case. I think i’m going to send mine off to get repaired and see if that works out. Idle air control valves seem easy enough to come by though.
