i just install my s13 sr20det, but it was idle at 1200rmp, anyone can help me out to lower the idle? thanks!
Adjust your TPS… I had the same problem after I cleaned my throttle body… didn’t put it back on properly.
DRE
where is the TPS? how to adjust it? thanks!
there is a screw between 2nd and 3d intake manifold pipe… (near the valve cover)… adjust that one
Mine idles at either 1800rpm of 800 rpm… If I adjust the idle there, it idles
at 800rpm or 0rpm
Isn’t adjusting your TPS and idle just a temporary fix anyways? There is probably another problem with maybe a vacuum leak somewhere and the idle will just go up again after awhile. Screw me if i’m wrong.
Don’t touch the TPS unless you’ve already screwed with it, you’ll just end up chasing a different problem. TPS is not where you adjust your idle.
1- make sure the throttle body is clean (you should have removed and cleaned it as part of your install prep anyway)
2- make sure the throttle cable isn’t holding the TB open.
3- run the engine until it’s warm. Note it should idle at 1500+rpm until it’s warm.
4- adjust the idle at the AAC (?) valve, between cyl 3 and 4 intake runner, big screw, should be 700 - 750rpm.
Note: before you adjust the idle you should ensure the timing is correct.
-Martin.
Martin’s right - Don’t screw with the TPS!
You can do more damage than good, like cause the throttle plate to stick closed.
