91 240sx super hicas s13 ka24de
Ok, I got my 240 a while ago and I know its been sitting around for some time before i got it and after i got it so I changed a few pieces. At first it ran real rough and bad and I found out one of my injectors wasnt working, got some injectors and then I had 4 cyclinders again. Then I got it safetied (passed no prob, did alot OF work ;)) I got my 10 day permit and took it out for a spin. Since I had it on the road I find it runs nice when its cold, like when I go to work. but when it heats up and reaches normal temp it starts to like bog out, some serious hesitation/studdering and some backfires(small quiet ones) I’ve been taking backroads and was able to find that between roughly 2000-3000 (very random theres no noticable pattern at all) is when this occurs. And sometimes It’ll run fine between 2-3k rpm, but I’d say 8/10 times it happens.
I also notice that it doesnt really have much power as well.
What I’ve done:
Bings 3" Exhaust Catback
AEM Intake
New Rotor Button
New Distributer Cap
New Accel Wires
New Plugs
New Oil/Filter
And I’ve even switched the maf to see if the sensor was gone, was ok
cant get orignal o2 sensor out, I do have a new one tho :P.
The spark is good,injectors work, cant find any leaks, everything is tight
it wont keep a steady idle for etest and the problem occurs when stopped and while driving. Engine also makes a constant clicking noise too when warmed up.
If anyone can help I’d appreciate anything.
