S13 will no longer signal, it seems intermittent. As soon as I turn the blinkers on, it either stays on solid and doesn’t blink, or blinks really quick randomly then stays on solid. Signal ights outside of the car do not light up when doing this. I checked the fuse by the kick panel quickly, but the fuse was good. Any ideas?
i had this problem b4. itz the flasher relay, its found near the steering column bracket above the pedals. actually its hidden/mounted behind it. i’ll see if i can take a pic. thers one bolt that holds it down.
get one from the junkyard or from someone whos parting their car.
sweet, I’ll have to check it out. A picture would be appreciated.
here it is. mine is already unbolted and jus hangin loose.
heres how the relay looks like. (its $50 to $70 bucks brand new)
http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizard.jsp?year=1990&make=NI&model=240-SX-001&category=All&part=Flasher%20Relay&dp=false
Car’s all fixed, and if anyone else has this problem, you can purchase a new relay from napa for $17. It doesn’t screw into the original location, just zip tie it up there.
