okay so the issue goes,
my left turn signal light used to blink really fast (i’m talking from the inside.
i don’t know from the outside, my rear was working for sure)
and my right one was working perfectly fine, and all of a sudden,
the both sides turn on solid when i activate the turn signal, by solid
i mean no blinking, the light turns on until the turn signal deactivates
the light’s solid both on the cluster and on the outside…
definitly flasher relay, napa stocks a generic relay for 17 bucks, its a black box beside the steering column. if you search there should be a thread with a pic.
change the light bulb
maybe u’ll need the socket as well(doubt it though)
the solder on the tip of the light bulb melted and link ur left signal circuit w/ the running light circuit
lol u called it on the dot Zeta_G, this time the solder wasn’t melted
i had the wrong bulb, instead of having 2 soldered tips, mine only had 1 and
it was originally made like that lol, thx man
