Installing a "Diesel Switch"
So I have the dreaded/inevitable/harmless VTC rattle.
After pulling the valve cover again today to make sure everything was in order, I still had what I thought to be a timing chain rattle.
The tension/tensioner was fine, so I searched a little more to find the VTC issue.
I was getting this intermittently, mostly on decel/shifting to neutral to coast/etc. for the past week or so.
This evening I unplugged the VTC, and it was perfectly quiet, and I even noticed some more oil pressure (although this might have been because the car wasn’t fully warmed up).
I stopped, plugged it back in…and the noise came back during driving, along with the lower oil pressure.
I want the VTC performance, but am annoyed with the “diesel” sounds.
I don’t want to replace the sprocket and solenoid, as it’s real expensive, and only a temp fix…i.e. it seems to happen again quickly.
Hence the “diesel switch”…
I can switch on the diesel noises and the performance when I need it, then switch it off for daily driving.
I haven’t came across any real fix for this, besides replacing everything (~$800USD at least). Has anyone found a fix that I haven’t found?
If not, I’m going for the switch…lol
the solenoid is 160 USD and the Sprocket is 280 USD and its a better fix than anything else… cleaning the original cam gear is much harder because it is too intricate inside and you will really never get it fully clean. i have 2 spare solenoids i can ship you but it would be easier to buy new… that is your best bet i think dude
Sprocket on rhdJapan was over $600 usd if I recall correctly.
Where did you find it for $280?
http://www.frsport.com/Genuine-OEM-Nissan-Intake-VTC-Cam-Sprocket-S14-S15-SR20DET_p_13049.html
http://www.phase2motortrend.com/s1sroemincam.html
Google is your friend! i just ordered one of these for my car - lol
RHD Japan is out to lunch with that price…
Haha, thanks man.
Posting from the Blackberry, so limited access.
No problem let me know if you need anything I’ve sourced just about every part for my car here and have all the pricing!
Sweet…I’ll be in contact before the winter.
I’ll be tackling a re-build…
