alright right now, my alternator isnt charging the battery, my question is are there any fuses that i coulda fucked up that would stop the alternator from working? and im newb
you guys can prob tell
thanks.
does your car stall out when driving? if so your alternator is finished if the car doensnt start then its your battery
check to make sure both wires are connected properly as well as the grounds?
check the tension on the belts and re adjust
if the alternator is on its way out the accessories in the car will be acting up
if drivable get it checked out
hope that helps
