Posted over at LS1GTO.com as well but figured I’d give it a shot here too since there are some pretty good mechanics on here. Below is what I posted on the gto board. The only thing I really need to explain is the “dreaded key locked” thing. The lock cylinder has a little ramp that a pin rides up that GM used far too soft of a metal. A notch wears in it and eventually the key won’t turn at all. You pop the cylinder out, dremel out the notch, and everything is great. It’s about a 30 minute repair. On to my post…
First off, sorry for the long read but this is odd and having all the info might help someone.
05 M6 with 22k miles, stock other than brakes, axleback, LSS, skip shift eliminator and aux in mod to stereo.
A few weeks ago I got the dreaded key locked problem. Luckily a few times removing and inserting the key got it to turn and I got the car home and was able to do the cylinder mod. I drove the car that weekend a few times and everything was great.
I got in the car Monday morning and when I turned the key it wouldn’t start. The lights on my dash were going crazy, ABS and TC flashing, buzzing from a relay. At one point the car even turned over and started with the key just in the on position, not turned to start. Once started ABS and TC errors were on, the tach was jumping around between 2000 and 2500 despite the engine idling normally. Basically everything electrical was fucked.
I shut the car off and checked the battery, 12.2 volts. Battery connections good. Took the steering column apart, popped the cylinder out, everything looked fine. Made sure the security reader was lined up properly and put it back together. It still wouldn’t start, same jumpy electrical. Put some jumper cables on it, same problem. Then all of a sudden everything stopped and the car started perfectly.
Scanned with my OBD reader, no codes. Went to autozone and the battery tested fine, as did the charging system. Beat the piss out of the car for a little bit thinking if it was a short I’d recreate it, nothing. I drove the car for a week (it’s my daily driver) without issue until this morning.
This morning I open up the garage door and hit the unlock button and I hear the same clicking/buzzing relays. I look in before I even open the door and I can see the blue high beam indicator coming on and off. Then my trunk popped and I could hear my door locks unlocking multiple times. It won’t even try to start when turning the key. No click from the starter solenoid. Again the battery is at 12.2. I disconnected the battery and waited a bit and reconnected it. Still no go, still crazy dash lights. The check engine light was staying on even with the key out so I grabbed my reader but it wouldn’t even initiate a read. Turned the key to on and got 4 codes, 2 current 2 pending, all “N/A” with no code number. Then while I was sitting there with the key turned to on it was like the whole car rebooted. Gauges went back to normal, check engine light went out, and the car fired right up just like nothing had happened. Shut it off, started it, removed the key several times and it’s fine again. I even drove it to work today just to chance fate. Maybe it will get me home tonight, maybe it’s time to accidentally leave a lit cigarette in it and collect insurance.
I have no idea where to even start with this. I want to think it’s ignition related since it never happened until I took that apart. The only problem I had fixing the ignition though was when I first tried to put it back together the steering column lock had engaged and I couldn’t get the cylinder to go all the way back in. I pushed a bit on it and tapped it a few times but never put much force on it since the directions said it should slide right in. Shortly after I figured out how to push the lock back into place with a screwdriver and had it back together and it started fine. There are no stored codes now and I know if I take it to the dealer they’re going to give me the old, “the car is working fine now, couldn’t find any problems”.
EDIT: Battery is new as of 1.5 years ago. Quality Napa battery.
