Manual boost controller blow out...
yes i can, i have CS rad hoses, coolant tanks and turbo lines in stock at the moment as well as other products that CS brands but that are not branded CS like endlinks etc.
well i was looking at buying one of their turbo timer harness’s, steel clutch line and coil pack ground kit from a us retailer (frsport)
but if you can get some of that stuff ill gladly buy it off you
that is a possibility… my price will be about the same because it is branded stuff.
do you really need the grounding feature on the coil pack kit? because i have some seriously awesome coil pack covers coming out this weekend likely.
well the ground feature is nice…but if your covers are omgwtfbbq wicked then ill take one of them instead!
as for the other items i dont care if their the same price…or even a couple bucks more. i guess id just rather buy them from someone on this side of the border. wieeeeeerd
i have a clutch line in stock… turbo timer harness, i can tack onto my next order from wherever… coil pack covers should be ready this weekend.
I don’t get the diagram, why is one of the nipples not connected ot anything?
By the way, the “signal” is connected to say a vaccum block?
On a twin turbo setup do you need two of these? How do you hook it up for twins? Diagram anyone?
i duno about twin turbo but, i actually found the setup online a long time ago. and to the guy who cant get it down from 15 psi , to adjust it properly u have to turn it all the way down. and then go about 6 clicks and then drive and keep going up by 2 clicks till u get the boost u want.
15 PSI… i hope its not a small turbo like a t25… big risk of damage there if its not already broken
