I just picked up some 440cc injectors for my CA and i was wondering if using these injectors with the stock fuel pump is possible or if they flow to much for the stock pump?
Shit, bone stock my SR topped out the stock fuel pump. Usually cut out at high speeds, like on the highway. Swapped it, and probably wasn’t there.
depends on what you do! If you boost it up it will use lots more gas! But yes I recomend geting a pump!!!
