do you know what valve float is? If an engine had no rev limiter what so ever, it would obviously naturally stop revving at some point. This is called “valve float” Its crutial in understanding how to make an engine rev higher, because it is what stops an engine from being able to rev any higher.
Basically what it is is you get to a certain rpm and the vavle springs are not stiff enough to close the vavles fast enough anymore. By the time the valve is fully closed, the cam is already on its way down again. hence the name “valve float” the valves are never full closed they open and then close half way. Valve float isn’t one distinctive rpm, you will over about 100rpm go from having decent power all the way to only enough power to hold you at that maximum rpm.
So the first way to counter valve float is with stiffer strong valve springs. But the higher you rev the more shit doesnt work so well anymore. For example, everything thats heavy is now REALLY weighing you down, and should be replaced if you want to make any decent power. Cams start to become a huge restriction unless they are really big and were designed for a high revving application (thats why VTEC is so sweet), valvetrain components start to take a shit, and anything thats not balanced starts to put a hell of a lot of weird forces on things that wered designed to take it.
Thats why you’ll see balanced engines. this isn’t so that they’ll neccesarilly make more power (they might make 1hp more), but instead so that they will last longer at very high rpm. The wrong vibration will fatigue the metals inside the motor and cause premature failure.
So basically
yes you could raise your rev limit with aftermarket parts. lets make a parts list foran SR.
7500rpm:
Stock redline is 7500rpm. At this rpm we already have guys launching rocker arms all over the god damn place. So first thing first is rocker arm stoppers.
8000rpm:
Not making any power here what so ever. Cams are an absolute requirement if you want to have useable power at this level, however the engine wont blow up any time soon without them. An intake manifold wouldn’t hurt either, as the stock plenum is not tuned for engine speeds this great and you’re losing a lot of power here as well. Bigger cams require valve springs right away as they have more lift and a more aggressive drop off (faster valve close)
8200rpm:
Hydrolic lifters have got to go right about now, and you seriously need cams. Valve springs are a must aswell (however stock valve float is 8992rpm, dont ask how i know :P). Solid lifters, big cams and stiff valve springs. sweet.
8500rpm:
time to start getting serious, at this point i’d really try to lighten up the valve train, titanium retainers, titanium valve springs if you cheaped out last time, big big cams are needed to have any efficency at this rpm as well. Knife edge and balance the crank as well as blueprinting the rest of the shortblock. N1 waterpump is absolutly required at this point as you will be entirely out of hte efficency range of the stock water pump. N1 oil pump is a good idea as well. This should be good for about 9200rpm, if you can make power up there.
Ive never seen many SRs go much above 8500rpm.
