For those who don’t know; Megasquirt is a DYI standalone management computer that can be used with virtually with any car. When it first came out it was only used as a fuel computer. Over the years megasquirt has evolved into a complete standalone system that rivals the expensive aftermarket standalones that we see today. Heres a quick list of features megasquirt can control: fuel, ignition, iac, tps, fan, water/meth injection, nitrous injection, propane injection, boost control, Flex fuel, Knock settings, extra injectors, wideband auto-tuning, launch control, extra injector/s,datalogging, and much more.
There are so many possibilities with megasquirt so I’m just going to get into the basic info. Megasquirt uses a speed-density based system. In order to run properly, megasquirt will need to know coolant temperature, air temperature, throttle position, exhaust output (o2), manifold pressure, and ignition trigger. Megasquirt uses a built-in MAP sensor that can read up to 21psi. (You can easily switch upto a 4-bar MAP if needed). Megasquirt can use your stock sensors stock along with IAT and CLT GM sensors. These 2 sensors are very common and inexpensive. You can probably get away with using your own IAT and CLT sensors, but extra conversions have to be made etc…
There are several versions that support several options for megasquirt. The hardest part is figuring out what’s best for your setup. Depending on your needs, you can start out with a Megasquirt I processor w/PCB2.2 for about $140 unassembled /$240 assembled or go with the most recent Megasquirt II processor w/PCB3.0 for about $250-$300unassembled/$400 assembled. It is also able to mix and match (ex> MegasquirtI on a V3 board) to save money when you don’t need the added features.
Megasquirt connects to your PC or laptop via DB-9 serial cable. It uses open-source software called Megatune that can be downloaded off the internet. Megatune for allows you to setup VE, Spark Advance, and AFR tables. MegasquirtI will allow for a 64 point map (8x8) for each of these tables. MegasquirtII will allow for 144 point map (12x12). The V3 board allows for both low and high impedance injectors. Megasquirt supports/can control the following ignition modules: GM HEI, GM DIS, Ford EDIS, Bosch 0 227 100 124, MSD 6A, and Direct Coil.
This is about as far into megasquirt knowledge as I’m about to go.
Any more info on megasquirt can be found:
http://www.megasquirt.info/
http://www.bgsoflex.com/megasquirt.html
http://www.msefi.com/
http://www.diyautotune.com/
