Yes, I saw InnTune’s ad in theory-forum, but have further thoughts which were not answered there. His thread was more of a FAQ / how-to.
To reference:
Now, for what I’ve been debating for a few weeks with some gearheads.
From a performance perspective: Straight meth FTW - Meth adds fuel, which means it brings power to the table.
From a daily driver perspective: Straight water FTW - Water cools CC temps, and is ALOT easier on the injection equipment. Water cools the charge better, but doesn’t add octane of its own.
Material vs. Material…
Water is more effective then meth (by mass) at cooling the cyl. charge
Water vaporizes @ 212* F
Vaporizes 70* higher then meth, so will only help you once you get into the CC most likely.
Water is inert & will not burn. If it doesn’t burn, simply remains a gas… well now that steam is taking up valuable space - and not doing anything.
The volume of steam is now taking up space in the cylinder charge and actually making the charge LESS dense, and more humid - slowing flame speed. This means you have to run more timing, which negates some of the point of using water to battle knock. Of course, it’ll allow you to make more power then without it.
Oh, and water doesn’t eat rubber & aluminum.
Our friend Meth brings a bunch of octane to the table.
Meth vaporizes @ 149* F
Meth vaporizes @ lower temps then water, so it could actually start cooling the charge in the intake tract (150* IATs are not unheard of).
Now, Meht brings octane. Octane increase flamefront speed… now we can pack in a more dense charge then before & make more power.
Meth evaps earlier on then water, however, it will not take out as much compressive heat for the same reasons - meth doesn’t cool as well as water (50% per mass).
And of course the meth is bad on the pumping system with the eating of rubber & aluminum.
Heres where I start waivering, tell me if I’m correct.
The reason that we are injecting anything in the first place is that we’re talking about pure combustion chamber cooling (which is the same reason you run richer then stoich anyways). Bringing down internal temps, allows BMEP to be increased while keeping engine bits from melting & cancelling preignition effects.
So, technically speaking: If we’re injecting extra gasoline (running rich), meth (extra octane & some evap cooling), or water (great evap cooling)… it doesn’t matter - as long as you tune the setup to take advantage of the new found efficiency (BMEP), and work around the side effects of the fluid itself. Okay? Good.
Meth & water both bring cooling to the table, and both are effective knock suppresants (water because of cooling, meth because of octane). Water provides greater charge cooling with lesser amounts (per mass) then meth does. Water does almost 2x what meth does in this aspect. So, how much meth would it take to get upto the same efficiency of water injection?
Water > Meth, amirite?
