ET STREET™ AND ET DRAG®
AIR PRESSURE GUIDELINES
PROPER AIR PRESSURE
Proper air pressure is critical to the best performance of your ET Drag or ET Street racing tires. Recommending air pressure is not easy, since there are so many variables that affect it: i.e. weight distribution, transmission, chassis set-up, wheel size, etc. To help you, we have broken down the types of vehicles into the following six categories with a recommended starting point for the correct air pressure. Keep in mind that these are only starting points. Actual optimum air pressure may vary significantly. If you have been running another brand of slick on your racecar, we generally recommend you start with the same air pressure you were running and go up in ½ pound increments until you get the best performance. Most racers will usually end up with ½ to 2 pound more air pressure in a Mickey Thompson tire.
Note: Many racers feel that “Less is Better” with regard to air pressure. This is not always the case. While there are exceptions to every rule, we have found higher pressure generally works best with Mickey Thompson Tires. Not only do the higher pressures lead to quicker times, but they also contribute to a safer, more stable ride at the finish line.
ET DRAG® AND ET STREET™
VEHICLE WEIGHT
TIRE SIZE
AIR PRESSURE
UNDER 2,500 POUNDS
UNDER 2,500 POUNDS
UNDER 30" DIAMETER
OVER 30" DIAMETER
6 P.S.I. AND UP
4 P.S.I. AND UP
2,500 TO 3,000 POUNDS
UNDER 30" DIAMETER
OVER 30" DIAMETER
8 P.S.I. AND UP
6 P.S.I. AND UP
OVER 3,000 POUNDS
OVER 3,000 POUNDS
UNDER 30" DIAMETER
OVER 30" DIAMETER
16 P.S.I. AND UP
10 P.S.I. AND UP
ET DRAG RADIAL
UNDER 2,500 POUNDS
UNDER 2,500 POUNDS
UNDER 30" DIAMETER
OVER 30" DIAMETER
16 P.S.I. AND UP
12 P.S.I. AND UP
UNDER 30" DIAMETER
OVER 30" DIAMETER
16 P.S.I. AND UP
12 P.S.I. AND UP
OVER 3,000 POUNDS
OVER 3,000 POUNDS
UNDER 30" DIAMETER
OVER 30" DIAMETER
16 P.S.I. AND UP
12 P.S.I. AND UP
When working with ET Drag Radials use 1 psi adjustments to see change.
A radial will perform quicker the more air you can run.
The burn out should begin once the rear tires are completely out of the water box.
ET DRAG MOTORCYCLE
MCR² (3295): Quarter Mile in 7 seconds, Turbo Bikes, 6 - 10 psi
Quarter Mile: in 8 to 9 seconds, 15 – 19 psi
Quarter Mile: High 9 seconds and slower, high twenties to mid thirties
MCR (3299): Quarter Mile up to 9 seconds, 25 + psi
Stock or piped and jetted bikes, high twenties to high thirties
3053M (Pro Stock – Pro Mod): 4.0 – 6.0 psi, wheelie bar 2” - 2 1/8”
3064M: 4.0 – 6.0 psi, Wheelie bar 2” - 2 1/8”
3065M: 6.0 – 9.0 psi, Wheelie bar 1 ¾”
3073M: 7.0 – 8.0 psi, Wheelie bar 1 ¾”
3220: 7.5 – 10 psi, Wheelie bar 2” - 2 1/8”
3221: 6.5 – 8.0 psi, Wheelie bar 2” - 2 1/8”
3222: 6.5 – 8.0 psi, Wheelie bar 2” - 2 1/8”
These recommended pressures are guidelines only, actual pressures may vary.
Wheelie bar settings are guidelines only, with the front end extended and can vary
ET STREET RADIAL
On the racetrack DO NOT use starting pressures below 11 psi.
Recommend pressures for:
P295 and larger sizes: 11-14 psi
P275 and smaller sizes: 12-16 psi
On the highway we recommend running 75% of maximum psi stated on the sidewall of the tire.
ET DRAG JR.
3621: 4 – 8 psi
3644: 4 – 8 psi
Mickey Thompson also recommends that you invest in a good tire pressure gauge and that you keep accurate and complete records of each pass. This will aid you in becoming a consistent performer.
This is Mickey Thompson DRAG / STREET Technical Bulletin #3.
For more information regarding Mickey Thompson Performance Products ph: 330.928.9092
