Some people on another site had asked me about my solidworks models. Most of these projects have been aborted with the change of powertrain but you still get the idea:
Its extremely helpful for me to be able to look at it in solidworks and spin it around to plan everything out. Even if its simplified, if the dimensions are right it still gives you a good idea of the fit of everything.
I have a few more of both ongoing and aborted ideas:
The manifold was designed to have no bends with less than a 2.5" CLR and to feed the turbo directly into the back of the intercooler. The inlet for the turbo would be immediately below the d.s. frame rail allowing me to create an airbox in the bumper.
I’ve obviously decided to go a different route now. I had to make a tough decision of whether I should continue spending money to fine tune a setup I had, or to switch over to the setup I knew I would go to sooner or later.
Took a hand off the grinder, it caught and flung the other hand into the metal I just cut. Got me straight across the knuckle. Ironically I was using the grinder to take the sharp edges off the metal and hadn’t done that one side yet.
Exactly the conversation we had immediately after the incident.
New transmission came in today: K20Z3 6 speed OEM LSD with low milage. unfortunately it has brought my attention to more problems with the motor; almost all the threads are stripped.
dude, that sucks. there is a clean k20a2 in here for sale for $3500. maybe just cut your loses, pick it up, and keep the other motor for spare parts / part it out?
The sleeves, rods, pistons, and from a brief look, the entire head are all good. That’s the real important bit, but if I find anything more wrong with it I will definitely start going another route and parting out what’s left.
I hate cob job shit and this block has it in abundance.
