i can hear this wear noise when the engines in neutrel but when u push the clutch down it goes away?Second problem is on start up it makes this really weird noise but i can’t pinpoint it, its somewhere around the fan area, and third the car makes a clanking noise when turning left or right above 40, and finnaly last my right light doesn’t go down and when i adjust fromt eh motor a little it will go up and down twice and stop.
Really weird noise (give more info).
Is it clicking?? If so, there’s a small electrical cable that runs to mafs and usually secured with a screw to the top of the plastic intake - check to see if it’s not flying into the fan fins with it’s plastic holder.
Clanking noise in turns - very likely it is your lower ball joint (check your wheel bolts first to save some time). Then try this - if it’s so bad it clicks - you could raise front of your car and see if the wheels seem somewhat loose - grab each wheel and try to move side-to-side and top-to-down several times. While you are there - shine a light and take a look at the ball joints while they’re mounted - one reason they tend to go is if they crack and s8 gets in there while lubrication goes out and they wear - shine some light on the rubber and see if you got grease / cracks.
If you could give more info, it’d be awesome - some of these ideas I gave are sort of shooting in the dark from the most common similar issues I’ve run into.
