well i have a 95 talon tsi awd and i wanted to know if there is an msd for my car? if so where can i get one?
techinically there is an MSD for all cars, if you really want to know i suggest contacting Jrex…the super awesome parts guy at hybrid. if there is one, he will find it
The MSD DIS 2 will work for your car. You may need to run their coils but it will work. Personally I would go Coil on plug before I started using an ignition amplifier. This way you dont roast old plug wires from the extra energy and if the grounds on your car are weak you will cause additional current to pass through the secondary ignition system eventually damaging something.
Coil on plug = much cleaner and efficient. If you need one we can probably help you out there
Don
Hybrid
Not that I don’t want you to buy an msd unit or any other product, but why do you think you need anything? What is your setup? What are your power goals?
i had msd on my car took it off that same week. i hate msd
I Always have had bad luck with MSD junk
this guy found a hair inside his msd
