Any suspension mods?
Hate to be a poke, but before you lay more power brakes you will have done and do suspension also. Go set of springs and shocks or coils.
My suspension is a pretty healthy set of Hicas (110lb) springs and Hicas sway bars, and polyurethane TC rod bushings.
I’m pretty happy with it for now. If I start feeling the power of 8 PSI (200-240rwhp or so) screaming suspension,
i’ll probably pick up some coilovers, likely Megans or Teins down the road.
That said, you do raise a valid point, and i’ve thought what i’m gonna do through.
Well assuming that brakes are for better performance over a longer period, ie resisting fade aka track driving… I’m also wondering why the turbo is coming before tires/wheels/coilovers/braces. But hey, if you’re into drag, go for it.
Oh yeah, I also have front & rear STB’s as well, and Nismo engine mounts.
Tires are Michelin Pilots.
I am into drag, actually. Not hardcore or anything, I mean this is mostly gonna be a
streeter (hence the stock ride height and looks), but I love all areas of driving, and
drag is definitely included. Cracking the low 14’s in my “Street car” would render
me satisfied. That would be all I need.
I have thought day and night about suspension and pros/cons/finances etc before
coming to my decision…
I should be in line for a few track events this summer (yes, that’s where the stock
suspension may suck a little…), but, by all means it’s not a track warrior. I mean, i’ll
be wintering the car, and so the stock suspension will be kind of a trade-off in the
whole thing.
If I wanted a race car, i’d do things differently.
Once the turbo is on and I feel the setup to be reliable, and pending consistent
cash flow, I may think about a few more goodies.
I may also be dynoing the car soon before all the turbo parts go on to
be able to compare. :twisted:
My outlook is that these stock DOHC motors apparently range from 115-135rwhp so I want to know where
I stand beforehand (with just an intake, 300ZX fuel filter, ground wires, Magnecors, HF cat &
tune-up that is).
Anyone else think I should do or skip the pre-turbo dyno?
I wouldn’t bother with the dyno… but I WOULD run it down the strip. It will be cheaper and you’ll at least get some seat time out of the money spend. But I suppose this assumes you’re not slapping on the turbo in hte very near future
Find a dyno day that other people have organized and just do a baseline run. It should be $40-50 bucks for one or two pulls. Anything more I’d say stops being worth it.
