i used to have the same problems all of the time with my old Toshiba laptop…it would get so hot it would just shut down. I had a cooler like the first pic u showed… maybe a little more expensive…but nothing like the second one… it did no good…
then I got a “laptop elevator stand” type of thing… it was like a black piece of plastic… with three “legs” kind of in the back that would put your laptop at a 30 degree or so angle… that proved the most effective for my comp… and while a lot of times it was just hot from all the use… it also helped to take one of those cans of “air” to the fans and vent areas… it really helped…
The cooler you have a link to is useless. I had one of those, and one with 4 fans, and they all do freeking nothing! i dont know why, but they put off like 5cfm and are generally loud… I just resorted to getting a app that runs my internal fans at full bore instead…
[/quote]
more info about said app?
the laptop is prolly 3 years old, its done this since the begining. ive been told replacing the thermal paste really helps, but thats above me…
What model laptop is this? Has this been a problem since day one.
On a lot of laptops with this issue usually it’s a case of cheap thermal tape breaking down over time, and the cooler fins attached. Depending on the model laptop it might be easy to do.
Yeah a lot of Dells that are a few years old had that issue. Usually was a 20 minute job to fix. The cheap thermal tape likes to crack, and lose effectiveness. Not allowing for any heat disipation
If you’re looking for some help cleaning it ILC, Boxxa (after he washes his hands), and I have done this sort of thing lots of times before. Id say clean it, or at least get it looked at by someone before spendng anymore cash on useless products.
