Need guage help!
Hey;
I have recently bought a oil/ coolant temp gauge, volt gauge, and oil pressure gauge.The problem is that i dont know where one needs to mount the sensors units?
-oil/coolant temp gauge: has a probe with some fittings
-oil pressure: has a small tubing with fittings on the end
-Volt gauge: has 2 terminals(I know one is any + wire, and the other is any ground)
If someone can help me with the proper location on mounting the sensors, that would be great.
Thanks a lot.
The oil pressure gauge sensor is mounted where the Ecu oil pressure sensor is. Which is right beside the oil filter. You need a “t” i think it is, so u can screw your gauge oil sensor onto and your ecu oil sensor, and then screw into the block.
Then run your oil lines to your gauge.
I also think that the coolant temp sensor, can go right where the ecu coolant temp sensor is, and its similar process like the oil pressure sensor install.
