need help finding wheels
ok, the track on the rear end of my mustang is 1" wider hub to hub than the front. i need 16x7 5x114.3 with 2 an offset of +45 ish and then 2 with an offset of +32 ish.
point me in the right direction.
taking all options?
or do you want something like the black 5 stars with the redline?
i got nuttin
:tdown: get better offset u have rwd
all options right now. i actually had a brain fart and forgot about the rota site. they seem to have some options.
another q.
if i step up to a 17x7.5 and my 7" wheel is already close to rubbing i only have the add .25" to my offset correct?
yes
werd
just to make sure i am not a total asshat, i would then need a +40 and +27
give or take, or am i going the wrong way?
do u want them pushed out more or tucked in…offset is centerline of wheel to where it mounts to the hub…Larger the number more tucked they will be…less the more pushed out the wheels will be
with what i posted originally the wheels will just barely tuck. so i’m going the wrong way if i go wider, and would need to add not subtract.
i hate sizing wheels
haaaa. yes if u go wider and want them to be where they were with Orignal offset posted yes u need to add
double post
I don’t even think Hondas have that high of an offset. If you’re only running 7" wide wheels, you need to be looking for some closer to 0. You shouldn’t be looking for anything that high unless you’re looking for 9.5 - 10 inchers.
edit It also doesn’t matter how wide your axles are front to back, it matters how much distance there is from your hub to your fender.
Mustang…and he is trying to get the right staggered look
Really? I couldn’t tell. You also don’t ADD to your offset to get the bigger lip out back, you SUBTRACT.
i’m try to get it not staggered. thats the problem i have now. i need 8mm spacers just to get the wheels on the front.
he doesnt want more lip out back…he found the perfect offset in a 7" wheel now comptemplating 7.5 so me must add to get the same look
How do you expect a staggered look without a bigger lip in the back? :fail:
Because you’re using fwd wheels on a rwd car. That’s what happens.
are you dyslexic?
the rear end is 1 inch wider hub to hub, so the front wheels (that are in the oem location) need to be pushed out .5 inches each to match the rear end. the offsets i posted will just barely fit in my wheel wells. i CAN NOT have them out any farther.
edit:
and you posted again. you really need to stop posting in this thread. the SVO mustang used crazy offsets. please just stop.
