Need help plz
swapped a sr20ve head on a aviner block with T25, i pluged the oil return whole in the head and did the whole drilling and tapping to put a ve head on the det block. so i built the motor and installed it in the car, during start up it ides but my oil psi light is on and i installed a autometer oil psi gauge. I used a distribution block to allow to use my oil psi sensor (factory), my autometer psi sender, autormeter temp senser and oil return. My problem is that i am unsure if i have oil psi in the engine. The car ran for over 30min no knocking or strange noises. coolant temp gauge works.
how can i check if there is oil psi in engine. I plan to buy a new sender, i bought the gauges used so sender could be wrong, but also my factory one…?
i took the valve cover off and there is some oil pooling but when i had the car idling today i could not see oil beeing squirted on the cam lobs…?
  • oil is the blood of the car i am worried… help plz
cheers
rob
Might be better off checking sr20forum.com, they’ve got more than a few people over there who’ve done the swap.
thanks man i just tryin to post everywhere.
