Can some one help me or tell me how to pull out the ac and completely remove it
pull the ac out of what? a house a car a rv? details deatils details
out of a 92 civic hatchback
A BFH always worked for me
man you could ahve up ur post count had you posted this in general automotive or tech help.
unbolt it take the belt off … remove the lines slowly or release pressure from the valve first.
i’m not 100% sure onw hat your asking here?
thread moved
for 20 bucks i will
BFH BFH BFH BFH
:ham::ham::ham::ham::ham::ham::ham::ham::ham::ham::ham::ham:
take an old towel, put it over a phillips screwdriver, press screwdriver into the release valve(looks like tire fill valve on the hard line or condensor) with the towel drapped all around the line. hold till it stops hissing. remove the belt, the pump, unbolt the lines at the firewall behind the motor lower passenger side. get new shorter belt. make plugs for the firewall ports you removed the lines from using a new nut and a washer with no hole in it. approximately 75-100lb weight savings and less draw of power from your motor. :tup:
I like to stick a screwdriver in the valve and shut the hood on top of it so the shit goes in the atmosphere.
