I have the Rear beltech drop springs but still sits higher then I would like in the rear, is there any other option spring out there or should I go Coil over QA1’s?
spindles???
did you install them correctly? you can install a spring two ways. one that will allow the spring to seat normal and allow it to have teh correct height or install it the wrong way where it will allow the spring to be higher then needed.
its all in how you point the pig tail. if you point it towards the driver side of teh car it will be at correct height if you point it at the passenger side itwill be higher then needed.
atleast this works on a stang
pigtails are pointed driver, , ,
rs/ss-rear springs.
:doh:
I’m confused. I thought you had an 8 second ride? How is that going to hook with lowering springs? And I would think you would need more clearance in the wheel well launching a 8 sec ride.
its a chevy not a buick so itll never do 8s
DAmn u u beat me to it :slap: Im sure alot of u should know by now that this douchebag has no 8 second ride well maybe in his little fanatasy world he does.
fat bitches or cement slabs in the trunk:D
he claims to have more then one SS so it might be for his other cars
I’m using Moroso’s Rear drag coils on my G Body…Different spring rates for each side, no air bag necessary to correct the launch.
They are about 1" lower than stock, I’m having trouble with the fit of my new 275 60 ET Streets though
Different car, claim quick, I do thanks!
lol, OK cock smoker, if you can’t help, please whore somewhere else! :madfawk:
Height, or width issues
lets see ur laughing then ur a :madfawk: makes alot of sense about as much sense as u saying ur car is an 8 second ride with no prof. :greddy:
hey,thats not me posting under sams name! :ugh2:
Laughing at u , case you didnt know but thanks, man why r you so pissed u keep bring that up, you act like I brag about it I mentioned it 1 time, so then what I post a slip, ur next fucking retarded comment will be its not urs so why bother, meet me at the track, times mean shit in my book, winning does, turn off the clock, and run-em, times i guess are great bragging rights for you, I could care less. Also thanks for NO help whats so ever,
Time to notcht the frame. I also used your setup when i used a full width 9" in my car. But I still used the air bag and it improved the 60’s a good bit
air bag from reading is a bandaid. anti roll bar seems to help along with adjustable shocks/CAs seem to be what helps dial in a rear suspension
I quess u dont remember me hanging out with cutty and his crew. Every fuckin time thats all u ever said is I have 1000hp and Im going 8 seconds. The next time u try to impress people ur hanging around with make sure there asrent people around that know what there talking about douchebag
