Figured i’d switch it up a bit and not bitch about my frequent car problems for a change.
My friend has a 2000 Pontiac Sunfire with headlight problems.
Checked fuses in the fuse panel on the driver side of the dash, they’re fine.
Had bulbs replaced.
When starting the car, the daytime running lights turn on for about 3 seconds…then flicker for another few seconds, then turn off completely. Will not turn back on. The high beams on the other hand are working fine.
When it’s not the headlight itself (if the bulb was shot the daytime’s wouldn’t come on at all), and the fuses are all good…what else should i be checking?
