need help with a tire size
ok my stock size is 195/60-15 and i can get 4 snow tires in this size cheap 205/65R15. my car is a stock 05 civic should i have any problem running these? a qick responce your be nice i wanna pick them up b4 someone else does
They will probAbly rub
i would think they would rub also
thx guys
I’m pretty sure you can run 14’s on your civic. If that’s the case…first pick up a set of steelies or inexpensive alloys so you don’t have to pay for mounting and balancing back and fourth. Second, you can get 14" snow tires dirt cheap. Lastly, you want a skinnier tire for winter, not a wider one typically. Perhaps like 185-195/65-14
