need help with my sr20 swap
hi i need help wiyh my sr20det swap so if any 1 knows a shop that can finish the job or any 1 that can help me thnx
uhhhh ya
location ? what is left un-finished on the swap ?
89/90 or 91-93 S13 ? or is it a S14 ? S13 SR or S14 SR ?
vacuum lines stuff like that. the eng is swaped in the car done. my # is 416 828 0922 if u can help me thnx
Hey man,
Well if its just vacumes and little things like that, just use fsm to hook them up, I figured it out, its pretty simple once you see it. Where are you located?
toronto finch/islingtin if u guys have any vacuum maps can u send it 2 me plz
How to hook up vacuum lines on your SR:
http://www.sillbeer.com/vaccum.php
thnx guys so the vaccum source on the bottom of The throttle body i dont need so shold i close it???
close it
thnx that helps alot …1 more thing can i use a 5E ecu on my redtop???
it wont work well…62 wil work on black, but E5 doesnt work that well for redtop…ive had problems with the car not shutting off after u take the key out a few times when using e5’s on redtops.
however, if u have a blacktop harness with an E5 ecu…it might work ok.
If you use a blacktop harness with a redtop motor you will need a blacktop O2 as well.
isnt the only difference the actual size of the sensor. I think so. So you could just cut off the plus and splice them together, other wise I do believe an 87 300z turbo o2 will work make sure you get the fat plug not the skinny one
