Well I was away for couple days and when I got home the computer was freezing. I then turn it off and tried to turn it back on again but nothing happened. It doesn’t start at all. So I thought the power supply is dead and got a new one and still wont start. The mobo has a red light turn on when the power is plugged in. I’ve tried to removed the rams then vga but still won’t start. Anyone has any ideas? Thanks.
Intel E5200
Abit IP-35E
I have that motherboard. Try taking the battery out and pulling the jumper for the BIOS reset. Leave it like that for 20 minutes. That motherboard has a “backup” BIOS which has a safety trigger of sorts.
Hell, you may even go to turn it on tomorrow and it’ll work.
Also, remove everything but RAM, Video, CPU and motherboard as you do all of this.
Good luck :tup:
It doesn’t work. Anyone wants to take this job?
if you want to drop it off at my apartment, I can take a look at it for ya and see what I can do.
Im out in amherst by sheridan and transit.
I charge reasonable prices
And if I can’t fix it… no charge of course
