I’m currently have problems with my 91 240sx, need help to find what the problem is. Im going to try my best to explain the problem.
This started happening recently, when i shift into reverse and get the car moving there is this grinding sound, (not the same sound of gears grinding) more of a rougher sound. I have to stop the car, put it into neutral and then reverse, or i just step on the clutch again.
Same problem when im on a hill, and shift into gear 1, the car tends to roll back a little and the same grinding sound occurs.
My other problem is a constant sqeaking sound when driving, it sounds like a belt is slipping but not to sure. It is the same sound when you are reversing a car.
Any help would be much appreciated
thanks
champz
