The 636 I just picked up is fantastic, I may make a thread about it soon.However, I wanted to ask you bike guys a quick Q. It was lowsided at about 20mph and has minor scratches to the plastic and crankcase cover. Other than that the bike is perfect.
The only thing I am noticing is that when I am at speed and let off the handle bar it always seems to track just a cunt hair to the left. It is so minor and I am probably worrying too much but I want to be sure.
What’s my best plan of attack to make sure I am fine? Reputable shops? Possible causes?
Any leaks from the fork seals? Check for oil on the forks and surrounding area. One might be bad. Not an expensive fix if that’s the case. If you do one, might as well do both since you’ll have them off. $150 for both if you pull them off and bring them to freewheelin. Consider the option of new springs as well. You won’t need them, but they are an awesome addition.
If it’s not that, then have a shop inspect the bike for straightness.
No leaks whatsoever. I called Kawi in Jamestown and it could very well just be twisted. Releasing the pressure and loosinening the bolts may just fix the problem. It could also potentially be the front tire since its pretty old.
put it on a rear stand, spin the tire, watch. if you need to put it on a rear stand lmk, I’ve got one. But it doesnt look like you’ve got spools so you’d have to stop and get some from like freewheeling or wherever.
Check to make sure the forks stick through the triple clamp exactly the same amount. The front axle could be tweaked or loose too.
I would loosen the top and bottom triple bolts (supporting the bike obviously), and the axles and pinch bolts, loosen everything then re tighten it all.
