this is for a 95 acura integra w/ a b18b
i’m installing a new headgasket and arp headstuds/headbolts on my motor tomorow because i am pretty 90% sure i have a blown headgasket
(fuck it i already bought the parts anyways, and im boosting; rather be safe than sorry)
My only question is are the torque specs the same as would be for oem headstuds/bolts? maybe it’s a silly question but cannot hurt to ask
The car was doing this: which lead me to believe a bad headgasket
-Overheating
-Burning coolant, can smell coolant thru the heater
-blowing white smoke out of exhaust
There was no oil/coolant mixed together in either the oil or the overflow, which i guess is a “good sign”
Also, i am guessing there is something wrong with my radiator fan, as it has not moved, i cant remember it actually ever moving since i’ve owned the car.
I got a new slimfan, along with a half size radiator that i will be throwing in as well because i need to, but should i also replace the fan fuse/relay? since it is not working? or is it something else
Supposedly my waterpump is new, so i am not going to attribute that to my problems, and i trust the guy, but i did purchase a new thermostat/gasket since i have to replace the whole cooling system, and its only a 12$ part.
-Upper radiator hose was extremely hot, i forgot to check the bottom one, i cannot remember what it means, but either way leads me to believe it is malfunctioning/stuck
What else should i check while im doing all of this that could attribute to shitting cooling?
My idle is F’d, so im going to be cleaning my FITV & IACV, as well as replacing the intake manifold gasket and checking all vacuum lines
i have brake cleaner, what else would u recommend for cleaning the iacv/fitv that would be better?
And last but not least (lol sorry), which type of coolant would you suggest me running?
Thanks if you actually read this!
I remember you, you were mad cool and your jeep was pretty cool (for a jeep). Enjoy the tires and thanks for the business.
and pulled over and nothing was leaking, everything seemed fine etc etc
