No oil from pushrods?
Not exactly sure how to define, but it was more than normal rocker or injector ticking, but not as bad as rod knock (I unfortunately know that sound from last year).
Took pass. side cover off also and it looks like even after sending the covers back to Canton to get modified that the front rocker arm was still hitting a little bit. So hopefully that was the noise, was causing false knock, oil will flow after running, and everything will be good. :x:
I need the rain to stop so the garage queen can go out on the road. :kekegay:
:boink
bot, that would be nice if it was just hitting the valve cover… i have had that happen before
