I HAVE NO POWER TO MEMORY WIRE
SOMEONE HELP ME PLEASE
Its a fuse
:doh: fuse is the first thing you should check with anything electrical
check the fuses
checked all the fuses 1 by 1
How about under the hood?
Are you talking about the fuses under the hood or the actual wire?
total…if you’ve checked EVERY fuse in the vehicle both in the cab and under the hood, try finding the wire(do you have the interior wiring diagram for your vehicle?) If all else fails…run a new one
listen to Mr. moble installer over here.
fuses under the hood. Alot of times when you lose contant power Its the fuse under the hood. But if all else fails Grab the Thick white one that goes to the ignition. or hell you can grab the contant power off the 4 ways.
is it in your civic?
did u actually CHECK the fuses? cause looking at them isint checking them
there is a fuse panel under the hood on the hondas, (most) that contains a fuse that powers the constant of the radio, and some other things ie. keyless entry or cigar lighter.
if you Looked at the fuses, try metering them or just replacing the one for that particular circuit.
also i know a few older hondas had a blank in the fuse box, it to controlled the constant of the radio, there is a break away tab there, pop it out, pop i a fuse, away you go.
have a nice day
Joe…working with my father in home remodeling i’ve learned to do a lot more extensive electrical work than Mobile Power Installation, nothing hard about running a constant feed power wire…correctly…
Now that i didn’t know, learn something new everyday ![]()
:kekegay:
