As stated.
Even if I stay idle for a while, it will bump me off make me log in again.
Is this expected right now?
Anyone else having this problem?
As stated.
happened to me. deleted your cookies/etc. relogin. fixed it for me.
Still happening to me since last week about.
X…
ditto
I had the issue on two of three computers that I use. It cleared up after a day with no intervention from me. We upgraded the software to the newest stable version and it uses a different cookie system which has caused errors when going from the old way.
there is no good solution other than what Jeff posted, and to be patient as it will clear up.
Please see tpgsrs custom title.
I made that title for a reason!!
I had to log in just once on every computer so I figured it was just part of the change.
If it keeps knocking you off delete your browser history, cached files and cookies to see if that clears it up.
I had this problem in IE. Some old cookie seemed to stay and screw it up. Clear them all and then relogin and I have been fine.
happens to me at work but not at home… must be an IE related issue cause I use firefox at home
Was having the same problem. Deleted cookies. No more problem. :tup:
I had the problem… I also know why it does not work anymore…
Do to the changes that were made to the site(the move to a new host)… If you had the “remember me” box checked and you were in when the site came up…before the “move” you will need to delete your cookies and then relog-in this will save your cookie(s) under the “new” host …
:wiggle:
I has nothing to do with the new host. Just the new version of the software.
piss… well I had to do it on all computers that I use at the time of the new version
happening to me as well. super annoying.
silly IE users
yea happening to me too its annoying to have to log back in 3 times every hour
clear your cookies
I ate all the cookies in my jar, no dice
So go take a poop. Should fix it.
