i had to cut and solder a piece of wire just off the header for my O2 sensor…it got too close to the pipes and melted so i re routed it away from the heat…
(car is still being funny, hesitating intermittently, etc…BUT)
i noticed the 02 sensor wire has 2 wires in it, one inside teh other with some insulation between. the sensor itself only has one wire coming off it though, are the 2 seperate wires just attached to 2 different things? I soldered the whole lot together assuming this… I dont understand why the one wire becomes two, and why they are inside one another
