My check engine light came on about a week and a half ago (go figure, a few days before my inspection is due) and still won’t go off. My oil was due to be changed today, so I had the guys hook up the sensor and get me the code. There was infact two of them, so I am looking for advice on what I should do about them.
This is on a 2000 xterra, 3.3v6, 4x2, automatic
P0125 - Insufficient Coolant Temperature for Closed Loop Fuel Control
P0360 - Ignition Coil J Primary/Secondary Circuit Malfunction
Apparently my coolent was pretty low, I guess my slow leak got to be a bit faster than I anticipated. So I am going to guess that may set off the first one? As for the other one, if anyone has any suggestions or has dealt with this before, I would appreciate it.
Thanks,
-adam
