1994 Acura Integra LS B18B1
The exhaust pipe runs under the pan, but it seems like I would be able to pull the pan out without lowering the exhaust. My question is for anyone who has removed one, will I be able to slide the pan out or will it catch the pick up?
you will need to just drop the header/turbo manifold and let it hang. I’m pretty sure the pan will catch the pickup.
That’s what I figured. Thanks
make sure u use gasket sealant and dont over tighten the bolts or it will smush the gasket and ya more leaks
if anyone needs work done just give me a call stop by my shop n ill do it for close to nothing if you supply parts
only use a genuine honda oil pan gasket and use very very very little rtv on it and youll be fine.
Yes, bullshit other ones do not work as well. I learned form experience.
thanks for the tips guys :tup:
