A quick bit of history on this problem: I have a Blazer that was sitting for a long time. Did the basic tune up on it and was regularly getting a random misfire code. I replaced a few more of the ignition parts that looked worn out and was still getting the code anywhere from immediate at start up to 10 miles down the road. At this point I’ve replaced: Cap, rotor button, wires, spark plugs, coil, and checked every ground in the engine bay.
I was still getting the code (although less frequently) and my research pointed to possibly a worn distributor gear. I bought a new distributor from Summit and it had a new cap/rotor with it also. I replaced it by the book to set top dead center and point it to wire #1. It started up and purred nice.
But now I am getting P1345 - camshaft/crankshaft position correlation fault. Also, it smells like it is running rich and moisture (doesn’t smell like gas) is coming from my tailpipe.
Yes, the camshaft sensor is plugged in and getting power. I didn’t check the crank sensor but I didn’t touch it either. I also tried to rotate the distributor 1 tooth counter clockwise. It ran like shit at that tooth. 1 more tooth counter clockwise it didn’t even start. I still intend to move it 1 tooth clockwise from the original location too but haven’t had a chance yet.
Can anyone out there in Pittspeed land offer some suggestions?
I read of a ‘re-learn’ procedure that may or may not exist to help me.
Are Summit distributors junk?
Is the rich, gas smell possibly related to this?
Can anyone get some official GM documents related to this issue?
I am going to borrow a buddy’s snap on diagnostic tool. It should be able to tell me the offset of the timing to see if I’m in the ball park.
EDIT: it’s a 98 S-10 Blazer with a 4.3 W VIN motor.
