Figured Id show you fellas my the build of my car that started in august of 2007
Bought it in the summer from a local garage that was taken in as a quick buy to get a guy his dui fines payed off cause he obviously hit a guard rail with it.
Im gunna get more pics up of the build tomorrow but a general parts list on this car is basically.
back to front
Rearend
Prefab gbody ford 9’’ housing
Ford 3.70 gears
Moser 28 spline axleshttp://www.pittspeed.com/forums/showthread.php?t=49214
Hoosier 10’’ drag slicks on weld wheels
Trans
Gm TH350
ATI 2800 stall converter
Eagle flywheel
Oem starter
Engine
383 small block
stock pan
eagle crank
eagle rods
speed pro bearings
speed pro 10.5:1 pistons
Heads
Top End
Performance products dual plane intake
Comp Pushrods
Performance products 1.6 rockers
Holley 750 carb
Zex spray plate
Nos powershot 250-300 set up 10 pound bottle
Oem hei distributor
Random shit
Nos purge kit
Hurst Roll control
dual spal fans
I has dyslexia
these are just pics from this sunday at beaver springs we got it to 12.001 ill get some build pics up tomorrow
Looks like a pretty solid build you got going. You guys happen to be making it out to Beaver on Friday? I think I will be attending to spectate with some of the local PSULPAC guys.
blew the rear end out this sunday at the beaver on the first hot lap, surprising it didnt scatter didnt take it out yet but im pretty sure one of the axles are stripped, ordered a set of 4:11’s with 31 spline axles that will hopefully will be here by friday.
