Pewter 01 Z28 Cammed, Stalled, and more
2001 Camaro Z28 For Sale with a bunch of mods. auto, cloth interior, t-tops. Hate to see it go, but i need something a little more practical for the family.
PERFORMANCE
LUNATI 221/221 558/558 112LSA CAMSHAFT
LS6 VALVESPRINGS
THUNDER RACING PUSHRODS
OBX STAINLESS STEEL LONGTUBE HEADERS &
Y PIPE
CUSTOM STAINLESS EXHAUST
FACTORY LS6 INTAKE MANIFOLD
RACETRONIX FUEL PUMP
FORD RACING 30LB FUEL INECTORS
MTI CLEAR INTAKE LID W/K&N FILTER
NGK TR6 SPARK PLUGS
TAYLOR THUNDERVOLT PLUG WIRES
OPTIMA RED TOP BATTERY
JEGS CATCHCAN
MOTORAD 160 DEGREE THERMOSTAT
FUDDLE RACING 3400 STALL TORQUE
CONVERTER
B&M TRANSMISSION COOLER
PROTHANE ENGINE AND TRANSMISSION
MOUNTS
TA PERFORMANCE DIFFERENTIAL COVER
WELDED AXLE TUBES
BILSTEIN SHOCKS
EIBACH SPORTLINE COILSPRINGS
AUTOMETER TRANSMISSION AND COOLANT TEMP GUAGES MOUNTED IN A PILLAR
ZEX NITROUS SYSTEM – SET UP FOR 100HP, CAN GO TO 150HP
CUSTOM PCM TUNE FOR MAXIMUM PERFORMANCE, DRIVEABILITY, AND SAFE USE OF NITROUS
APPEARANCE
FIBERGLASS SS SPOILER W/SPL LED 3RD BRAKE LIGHT
PROJECTOR HEADLIGHTS/CLEAR MARKERS
HID HEADLIGHTS
LED BULBS IN MARKERS, TURN SIGNALS, FOG LIGHTS
GRAND SPORT STRIPES ON FENDERS
SHORTENED ANTENNA
BLACK BILLET GRILLE
BLACK POWDERCOATED 17X9.5 C6 CORVETTE WHEELS WRAPPED IN 275/40ZR17 FALKEN AZENIS RT615 HIGH PERFORMANCE TIRES
i also have brand new drilled/slotted rotors and new brake pads from brakemotive, and braided stainless brake lines still in the boxes. the brakes on it aren’t very old so i didn’t want to just throw them away.
the 10 bolt was replaced 2 years ago with one that had 23k on it. the axle tubes were welded before i installed it to try and strengthen it up some.
90,000 miles but as you can see it’s been just about rebuilt all over and doesn’t leak a drop of anything anywhere. the underside is very clean and body is great. interior is excellent also.
344hp/342tq on motor
428hp/435tq on 100 shot - keep in mind that these are through a big stall torque converter which will show lower numbers on a dyno
ran 11.839 @ 116mph BEFORE the cam was installed. Haven’t had it to the track since it was installed and haven’t sprayed it since it was on the dyno.
$9000 in Hermitage, PA and have title in hand
email me at hallass@gmail.com and i’ll get it right away on my phone.
[ATTACH=CONFIG]18964[/ATTACH]
[ATTACH=CONFIG]18962[/ATTACH]
[ATTACH=CONFIG]18963[/ATTACH]
[ATTACH=CONFIG]18961[/ATTACH]
[ATTACH=CONFIG]18960[/ATTACH]
