Place to have injectors cleaned?
I have a set of Multech 2 injectors that have been sitting around since last august that aren’t quite workin anymore. i’m sure all they need is a good cleaning but i’m told someone needs to specially take care of this.
they only have 23K on them so i know that they should be good.
anyone know of places to go?
they will be out of the car.
seafoam?
what you need: injector clip (or alligator clips)
1 AA battery
1 switch
carb cleaner
hose to fit over the injector inlet
air (motorized pump, compressor, etc)
wire in the switch and battery to the injector clip. Put the hose on the end of the injector, spray some carb cleaner in it. flip you switch to apply voltage to the injector so it’s wide open, turn on air compressor and watch your carb cleaner go through the injector at 80 million miles an hour. reapeat a few times. do it to every injector. clean.
that’s just the ghetto way (which works great) but the proper way would be to send them somewhere like RC engineering and have them ultrasonicly clean them and give you flow test results including flow patterns and everything. Neat shit really.
I’ve done the ghetto way with my DSM injectors and it worked excellent.
www.cruzinperformance.com
12 an injector, done and done
killer link don. That’s cheap and pretty close seeing as everything is cali based usually.
This place rocks!! I had a set of Denso injectores cleaned here; Rich does an excellent job.
I’ll try that if all else fails, but i was hoping to have it done before the weekend.
anything local?
search, I’ve asked before, here or on the other site. But many options were discussed due to my lack of desire to use RC
JnJ may have a local contact that cleans them but as far as the whole process (clean, balance, new screens, o-rings, etc), Cruzin is your best bet.
Just an FYI for everyone,
the NAPA on Wherle costs $18 an injector and told me they’d have them the same day i brought them in. IMO it’s worth it, especially if you don’t have the time to wait a week on shipping them out and getting them back.
i’ll be taking mine there tomorrow.
They did a killer job on my injectors! A++ for this place.
kenedys on nfb does them as well.
u know how much they cost?
for 4 injectors it was like 60 or 80 he quoted me. thats for flow test, cleaning, replacing the orings and retesting.
best post EVAR!
Rich does an incredible job for decent price & quick turnaround.
