My s14 was driving fine all morning untill I went to wallmart. When I got out of walmart I notice my hasard lights are stuck on solid without the pusling. I get in and start the car and still they stay on. I am thinking the cold weather and n old relay didn agree with eachother but I can’t find the relay box only the fuse box. Anyone ever experienced this before? Can anyone help me ? My car will die if I don’t find the relay soon. Thanx any help at all would help.
if its the same as S13’s, it should be around the air box/intake in the front right corner under the hood… that’s where mine are on my S13 i believe. It looks virtually identical to your fuse box except it has a diagram of the relays on the top of it.
There are some relays in the driver side kick panel - I can’t remember if it’s there, but you can have a look, it’s easy to find.
Thanx guys, with some research I finally located them under the dash next to the gas pedal. Now I just have to pray it won’t get stuck closed until I get a new relay.
