I have a house built in 1920. I think it still has the original soil stack. It is a two family, I live in the lower unit. We totally remodeled the lower bathroom, then we noticed a leak coming in our ceiling (where the upper bathroom is.) I figured the floor was rotted out around the toilet upstairs, and the wax ring was not sealing.
A good buddy of mine worked for a plumber for several years, so he knows quite a bit.
He agreed to help me replace the rotted subfloor around the toilet, and basically remodel the bathroom for the tenants.
He quickly figured out that the toilet was not leaking at all, even though the floor was warped and rotten. We replaced the floor anyways.
The problem is where the sink drains into the main soil stack. The previous owner had a copper pipe jammed into the stack, and they put a shitload of epoxy around the fitting.
We figured that they were just being lazy, and they cut the pipe off or broke it off. So we spent about an hour with a MAP gas torch, and torched the old copper pipe out of the cast stack.
We pulled the pipe out (nearly causing a fire), and we installed a proper donut into the cast, and ran the PVC drain pipe to that.
To test it, we ran some pressurized water directly into the plumbing. It turns out that the cast stack is leaking right at the bottom of the Y fitting. That explains why the previous owner tried to install a homemade sleeve to stop the leaking.
This is on the second floor of a 3 story house, and the cast iron goes out to the roof. Replacing the stack from the 2nd floor up would cost a shitload of money. The labor would be insane, and it would replace the cast with PVC.
So right now for an emergency, I bought some JB “Waterweld”. I have used this stuff in another apartment before to seal a rust hole in a bathtub, and it lasted for 5 years.
I applied the waterweld to the leaking cast, and it is not leaking anymore, but who knows how long it will last.
For right now, we have tenants upstairs who need (and pay for) a working bathroom. We remodeled the entire bathroom, and left an access panel in the drywall so that we can have it fixed right when they move out.
I have a fucking roasting pan sitting in my bathroom ceiling to catch any water that may drop down, nothing yet, but I’m paranoid. Instead of replacing the ceiling, we just cut out all the wet parts, and used clear plastic sheeting to seal it off (so I can see if its leaking).
Does anyone have any idea of a more permanent solution than a JB weld product?
The only thing I can come up with is something like this.
http://www.fernco.com/waterworks/flexible-couplings/flexible-tap-saddles
But I would prefer a custom metal piece that inserts into the stack, sealing it. Not a ghetto copper pipe epoxied into the stack. If such a product doesn’t exist, does anyone have access to fabricate a custom insert?
I would like to avoid spending 3 grand replacing a cast stack, and I also like to sleep soundly at night not having to worry about sink water dripping into my bathroom (at least it isn’t shit water as first thought).
I have attached a photo I took today with my phone to show the pipe after we had “repaired” it and installed the donut and the PVC, and a photo of the finished bathroom. Between the floor, subfloor, faucet, vanity, mirrors, and lights, I have less than $300 into the project.
It is a rental, nothing high end like what is usually posted in this forum.
