Power line safety debate
So one of my coworkers was just explaining a DIY fix he did at his house that has me concerned. Figured I’d ask NYSpeed’s opinion.
Problem: The line running from the pole to his house sways in high winds (he’s on the lake) and makes a lot of noise right where it connects to his house. Opposite that connection on the inside of the house is his newborn’s room so the noise is a big problem.
His DIY Solution: Take two 15’ dock lines (basically cotton ropes), tie them together, and toss them over the power line. Pull them slightly taught and tie them off to his gas meter so it stops the line from swaying.
My issue: While cotton doesn’t conduct electricity, it does absorb water, and water does conduct electricity. To make matters worse he’s now made a path to ground through a metal object full of explosive natural gas.
His logic: The line is coated so it’s not an exposed conductor.
My logic: The power company spends lots of money putting out warnings about using ladders around your power line, so obviously they don’t have a whole lot of faith in that coating as a 100% effective insulator.
What do you think?
I wouldn’t fuck with it. I’d call a licensed electrician.
I am an AVID DIYer, and even I wouldn’t touch that.
I’m no electrician but your logic seems pretty sound to me. I don’t think the gas meter is a real concern for ignition but it just seems like a dopey idea to me in any event.
Why not call the power company and ask them to tighten it up some?
In for others input.
^ That was my advice.
Why doesn’t he just put a piece of rubber on the side of the house where it hits, to deaden the noise?
That’s an absolutely terrible idea.
Sounds like it’s not hitting the house. The noise is the ceramic mount shifting back and forth in it’s holder.
Which when he said that I said: “You know why that’s ceramic right? So it won’t conduct electricity”.
I can’t fucking believe someone would think that’s a good idea.
Good lord. This is why some people just shouldn’t work on their own house. LOL this one has me smashing my keyboard.
The wire isn’t squeaking, the anchor on his house is. If it’s squeaking that means its loose, and he’s now added additional load on the already loose anchor by pretensioning the wire. He’s going to wake up to the wire laying in his yard.
As far as grounding the power line to his gas line with a wet rope, yeah that’s fucking retarded.
please ask him for a picture so that i can post it on http://thereifixedit.com
Then darwin awards when a transient lights off his gas line and burns his house down.
:lol: srsly? This definitely sounds like a horrible idea.
I am pretty speechless. Tell him to undo the rope before someone fucking dies. This is a massive fire hazard in more ways than one. If he is adamant about fixing it DIY, then get a new porcelain insulator, and instead of passing the wire through it, he can tension the wire some by using one of these:
http://www.binet.lv/go.pl?IMG=36570611O2116
Then hooking this to the insulator on the house. He will have to create a drip loop so that any rain water can not run down the inside of the insulation on the se cable attached to the house.
Hey, sounds like the first to go in the fire will be the baby… That may not be a bad thing.
Tying off to the gas meter is the best part of his plan. If the wire breaks free from the house it will take out the gas line with it.
Yeah maybe he just bumped his insurance policy up and is looking for a payday? LOL
Anything that involves the powerlines and DYI is fucking stupid unless you are a licensed electrician.
https://youtu.be/bTZkH52Dwjc
Power lines into your house are aluminum right?
Time to bury the line. F that above ground nonsense.
Dan
Yes
